Different licenses for MR accesspoints?
redsector
on the Meraki website I found that there are two different licenses for the accesspoints.
https://meraki.cisco.com/products/wi-fi/models/#tabs
Is that new? I never noticed that before.
How can I find out which license I bought with all my old accesspoints?
Can I mix the licenses, f.e. in different locations/networks?
thanks
3 REPLIES 3
rwiesmann
there is a new one...the advanced wich includes an Umbrella Security license.
In the license inventory the license will show different.
further infos...check out this
https://documentation.meraki.com/MR/Other_Topics/Cisco_Meraki_and_Umbrella_Integration_-_MR_Advanced...
merakichamp
@redsector  definitely  the licenses you bought are enterprise licenses you can check that in your organization license info
the new license the advance MR license and upgrade license  comes with slight extra capabilities such as umbrella integration
but you need to notice the difference between the two new licenses because one that is  MR advance is applied to a new access point while the MR upgrade is applied to an existing enterprise that you bought
also note that this licenses support the per device licenses not cor-termination
kindly go through the documentation keenly
@redsector  it is only available for per device licensing and has to be applied to a complete network within an organisation.
