Authentication takes over 12000 miliseconds
Craig10
Authentication takes over 12000 miliseconds, is this normal? (see attached screenshot)
Devices on our network drop offline randomly on the Wi-Fi (both 2.4Ghz & 5Ghz)
Also, the devices in question 'hop' between APs quite regularly-is this normal? This screenshot is from 2hours connectivity this morning-
Any help would be greatly appreciated 🙂
10 Replies 10
Nope, what type of authentication are you using? I believe that is 802.1x. Does your server is on LAN or on the cloud?
The device constantly 'hopping' from AP to AP, is that normal?
Roaming is a customer decision but it is not normal for him to be "hopping'" from one AP to another all the time unless he is moving around a lot within the environment.
What Radius are you using? NPS, freeradius, Cisco ISE.
Cisco ISE
I recommend you perform packet capture and open a support case.
Craig10
Yes, 802.1x. The radius server is on the same LAN.
rhbirkelund
What type of environment is this occuring in? A warehouse of sorts? Are these clients scanners?
These clients are Windows laptops in an everyday office environment, nothing special.
BlakeRichardson
If you ping the ISE server what are the ping times?
The pings are pretty good-
