Layer 3 Routes
Layer 3 Routes
I'm cloning a replacement switch.  Doesn't look like it clones or moves over the layer 3 interfaces and routes.  Is there a good procedure for that other than documenting and remaking them all?
Edit:  Figured it out.  Can check the box and move them to the new switch presumably before hooking it up.
1 REPLY 1
Re: Layer 3 Routes
Yes, you found it.  On the Switch > Routing & DHCP page, select the interface and there should be a grayed-out "Move" button that becomes active when you've checked one or more interfaces, when you drop it down, you can select which other switch (or switch stack) in the network to move them to.
