MX-65
MX-65
Hi! MX-65 can be used in VPN Concentrator mode or NAT mode.
I have two links which will be terminated on MX65 and I need to do BGP configuration on same, along with Load balancing, VPN, DHCP.
Please let me know if it is possible to achieve and how?
4 REPLIES 4
Re: MX-65
You wont be able to use BGP to achieve what you want with an MX.  BGP can only be used for AutoVPN routes.
You can use NAT mode to do load balancing, VPN and DHCP.  Load balancing information can be found here:
https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Prefer...
Re: MX-65
@PhilipDAth Thank you for such a prompt reply.
I can use NAT mode for load balancing, VPN and DHCP but I won't be able to configure dynamic routing in that, right?
If I use VPN concentrator mode, then I can only see 1 WAN port on the dashboard, then what is the use of BGP in that?
Can you help us with your inputs in this scenario?
Looking forward for a prompt reply.
Re: MX-65
Re: MX-65
You wont be able to use BGP in the scenario you have described with an MX.  It is not capable of doing that.
You will need to use NAT mode.
