Client VPN RADIUS Attributes
Does anyone know if the client VPN supports the RADIUS server returning any attributes that can be used to limit access?  Actually I don't care if it is RADIUS, LDAP would be fine as well.  Just any method to limit access by user.
For example, with WiFi or 802.1x the RADIUS server can return a group policy to apply to the user.
1 REPLY 1
Hmm, it appears if you are using Systems Manager you can configure the client VPN to only allow those machines.
https://documentation.meraki.com/MX-Z/Client_VPN/Client_VPN_Overview
Now the question is can you then apply group policies (that work) based on dynamic tags.  I think not, since you can't normally do that for client VPN users.
