Play Store Apps
HuggyBear
Play Store Apps
Hello.
Trying to add a new Play Store app to my deployment, however, when I'm searching, its not producing any results... the app is on the Play Store, and even searching for "google" is not producing any results.
Is anybody else experiencing this issue?
Cheers
5 REPLIES 5
BlakeRichardson
@HuggyBear  what is the app you are trying to load? Maybe someone else can try loading that app and see if they have the same issue.
Its Microsoft Kaizala... I've managed to add the app via its package name (com.microsoft.mobile.polymer)
Cheers
Noah_Salzman
Meraki Alumni (Retired)
Search by app identifier (e.g. com.rovio.angrybirds)  seems to be working but I, too, am seeing 'no results' when searching by name. Looking into it.
Noah_Salzman
This is case 04302456. We believe we have the cause of the bug isolated, so there is a good chance it could be fixed in the next couple weeks.
VictorM
Hey all,
This is now fixed, and searching by name should be back to normal.
