Please don't upgrade your Meraki SM to 5.7.11, it does break phones in KIOSK mode. You will get this error message even though the APP is properly installed and I can open it if I exit KIOSK mode. Play store still has 5.7.9 but if you enroll your device using the Qr code, it will force you to install 5.7.11.
![Make_IT_Simple_0-1648092164064.png Make_IT_Simple_0-1648092164064.png](https://community.meraki.com/t5/image/serverpage/image-id/22452iAA3D466D096AC85A/image-size/medium?v=v2&px=400)
