Per SSID Band selection option allows setting target SSID to 2.4 GHz, 5 GHz, dual band, or dual band with band steering
- Select the 2.4 GHz checkbox to set an SSID to 2.4 GHz only
- Select the 5 GHz checkbox to set an SSID to 5 GHz only
- Select both 2.4 GHz and 5 GHz checkboxes to set an SSID to dual band operation
- Select all three 2.4 GHz, 5 GHz, and Band steering checkboxes to set an SSID to dual band operation with band steering
Per SSID minimum bitrate configuration option now allows setting minimum bitrates for all SSIDs directly from the RF profile page
