Per SSID Band selection option allows setting target SSID to 2.4 GHz, 5 GHz, dual band, or dual band with band steering
- Select the 2.4 GHz checkbox to set an SSID to 2.4 GHz only
- Select the 5 GHz checkbox to set an SSID to 5 GHz only
- Select both 2.4 GHz and 5 GHz checkboxes to set an SSID to dual band operation
- Select all three 2.4 GHz, 5 GHz, and Band steering checkboxes to set an SSID to dual band operation with band steering
![Screenshot at Oct 14 12-47-11.png Screenshot at Oct 14 12-47-11.png](https://community.meraki.com/t5/image/serverpage/image-id/20508iA864BC7F47C2547C/image-size/large?v=v2&px=999)
Per SSID minimum bitrate configuration option now allows setting minimum bitrates for all SSIDs directly from the RF profile page
![Screenshot at Oct 14 12-49-32.png Screenshot at Oct 14 12-49-32.png](https://community.meraki.com/t5/image/serverpage/image-id/20509i9AF8002B2130B87C/image-size/large?v=v2&px=999)
