Dashboard down?
nb12345
Dashboard down?
We just received a whole lot of alerts for all networks going down and then back up again, are there any ongoing issues?
thanks
9 REPLIES 9
GuiJrmo
We just got this as well for 40+ networks! They are all showing as backup now. Maybe the API Upgrade scheduled for this week?
Thank you! API upgrade?
GuiJrmo
This is what I am referring too! Not positive this is the cause just a guess.
got it! Not sure if that caused it maybe! Did you raise a case?
Malarkey_MX
We got over 130 alerts between 6:15 & 6:30 PM eastern. I opened a case to find out what's going on.
Grateful if you let me know whats they say!
Same. Hundreds of emails for devices going down then back up 15 minutes later. If you wouldn't mind, would you let us know what Meraki Support says from the case you opened? Thank you!
Any reply from meraki?
Malarkey_MX
Not much info from support other than there was a known issue on the 29th that caused the false alerts and it was quickly resolved by the development team.
