Wireless AP Daily Report Overview
Sonkist
Hello All, how can I get a daily report email of a snapshot or html format of this?
1 Reply 1
WadeAlsup
Hi @Sonkist
If you'll go to Organization > Summary Reports in your dashboard, you can narrow down your results to show just your Access Points and get quite a bit of information. You can schedule the report to email from there.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
