Sperate switch upgrade under the same network/template
AhmedJawad
Hi all,
  is there a way I can upgrade switches separately when they are under the same network/template? so if I have like 20 switches under the same network/template and 5 of them I don't have the approval to upgrade, can I ignore the upgrade for them?
2 REPLIES 2
Ryan_Miles
You can stagger the switch upgrades using staged upgrades. But you can't just straight up exclude or ignore switches in they're in the same network or template.
https://documentation.meraki.com/MS/Other_Topics/Staged_Firmware_Upgrades_for_Meraki_MS_Switches
@AhmedJawad if you set them all to upgrade a week or so in the future, you can then use the staged upgrades feature that @Ryan_Miles suggests to upgrade them in batches.  I believe if you leave the ones you don't want to upgrade in the last batch, you can then cancel that batch after the others have upgraded.  I don't think it is a supported option though...
