Routes installing is taking a long time
IotaNetworks
I have deployed MX250 as hub and is advertising about 30 subnets over VPN, when i added a new branch MX64, we see that routes for around 6 subnets are not getting active at all even after 12 hours of establishing VPN connectivity ?
Any hints to debug further and what could be the probable cause ?
1 Reply 1
DensyoV
What is the actual status of the VPN? Is it actually up? Can you try pinging from the spoke to the hub to confirm that the tunnel is up?
If the VPN is up and you are able to route traffic on it then most likely it is just a UI issue and you can contact Meraki support to see if there is a known issue about it.
Thanks,
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
