Meraki MX68 reset on RJ45 connect
Wade_Carroll
Hello all!
Every time I go to connect an RJ45 my Meraki MX68 cycles through a reset.  I've secured the power connection and the install location is over concrete so I don't think its static electricity related.  I also have a APC battery backup system in place.
The MX68 seems to be a very sensitive device and this is frustrating as it cause other issues with Wifi performance and client connections.
Any advice on how to resolve this would be greatly appreciated!
3 REPLIES 3
jdsilva
This sounds like one for support. I'd give them a call and get them to take a look.
You could maybe try a different firmware. What version are you on?
Thanks for the reply.  I've opened a case via email but will escalate to a call if needed (things are stable as long as I don't make changes).
This is the firmware:
Up to date
Current version: MX 14.40
Does it matter what device you are plugging in via RJ45?
If it happens with all devices you probably have a faulty unit.
