Configuration Advice
Karl0
If I can ask for some advice before i embark on this,
We have 2 x MX84s and 1 x Z3
Primary site (A) has MX84A Configured Hub(Mesh) With VPN from Z3 into it
Secondary Site (B) has MX84B Site-to-site VPN currently off - on the perimeter for traffic only for site (B)
Site A-B are connected via MPLS not via the MX’s
Site B currently has 3 VPNS coming in to existing non MX firewall,
I need to move the 3 VPNs (Non Meraki) from the old firewall to the MX – inbound to site B only, and not to effect site A is this possible under one company, can you have 2 Hub(mesh) configured?
2 Replies 2
jdsilva
When you're doing Non-Meraki VPN hubs don't actually matter (but yes, you can have as many hub as you want for AutoVPN).
If you want to only nail up a VPN to Site B you will need to control the Non-Meraki VPN via Peer Availability using tags.
Here's the Non-Meraki doc:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Settings#Non-Meraki_VPN_peers
And specifically, this section:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Settings#Peer_availability
Happiman
@Karl0
You need to create a "tag" and assign it to a program where you run the site-2-site VPNs.
The tag becomes the "Availability" for the non Meraki VPN
