Can I change an Ethernet port to act as a third Internet backup link?
Ricardo_Bagnoli
Hi There,
This is the scenario.
I have an MX84 which ports 1 and 2 will act as primary and secondary internet links (WAN 1 and WAN 2). However, since internet links will not be installed by the commissioning day I have been planning to get a 4G temporary router plugged to port 3 in the MX and somehow get it configured as a second internet backup link (WAN 3) in case the 2 internet links fail.
Is it possible? Can anyone guide me through a similar solution?
Thank you very much in advance.
Cheers!!!,
Ricardo
That is not possible. You can use a 4G USB stick but only for backup purposes.
Since you are only doing this because the two other main circuits are not ready - why not plug the 4G router into one of the two free WAN ports?
@PhilipDAth has a great point, use one of the WAN ports if you can.  If not I would get a new modem for your 3G/4G line of service and utilize the USB port.
See here: https://documentation.meraki.com/MX-Z/Cellular/3G_-_4G_Cellular_Failover
Ryan
BrooksEng
I have not tried this but you could give it a go.  4G Router plugs into Ethernet port and add a static route to that hop on addressing & VLANS > Add Static Route
