[NEW] MS17 – Security, Visibility, and Automation
[UPDATE: As of December, 2024, MS17 reached the Stable release stage. 🎉
Introducing the MS17 beta release – it's packed with exciting new features to help you elevate productivity with powerful security, enhanced visibility, and robust automation in your network! Head on over to the firmware management page and schedule your upgrades now.  Watch the new Meraki Switching Summer Update video and learn more.
Reminder: MS17 is available to all Meraki Switches, except for MS390 and Catalyst 9300-M.  MS17 Features.png
Powerful Security
  • Adaptive Policy extends to MS130X and MS130R models. Powered by Cisco TrustSec Security Group Tags (SGT) technology, Adaptive Policy dynamically identifies and enforces security policies for users, devices, and applications with network-based micro-segmentation.  With the extended Adaptive Policy support to MS130 mGig, MS130R, and Catalyst 9300-M, you can protect your network with consistent policy across different environments.
    • Learn more about the feature and use cases here or check out this documentation on technical details.
    • Please note, Adaptive Policy is a GA feature on Catalyst 9300-M and MS390 today. However, Adaptive Policy on MS130X/R will remain on early access page until MS17 reaches release candidate (RC) stage and will require an advanced license.
Robust Automation
  • SmartPorts: Allow dynamic application of port profiles via learned attributes (zero-touch port provisioning). This will help users manage ports at scale while saving time and minimizing potential errors in:
    • Defining automation for configuring ports based on connected device recognition
    • Saving countless hours during initial deployment and change management
    • Automating profile application based on connected devices, using identifier such as MAC addresses, OUIs and Link Layer Discovery Protocol System Descriptions.
    • Enable SmartPorts - Automation on Early Access page after upgrading to MS17 | Refer to documentation
    • Tune in to our Meraki Unboxed Episode 105 and learn more about the use cases
  • Intelligent Capture: With the new Intelligent Capture integrated in the Meraki dashboard, we've reimagined embedded packet captures to be even easier to take and analyze, streamlining network and security operations with enhanced monitoring.  Listen to this latest Cisco Champion Radio and learn more.
    • Store and access securely in one central platform
    • Streamline troubleshooting workflow with a built-in packet analysis tool
    • Enable Intelligent Capture on Early Access page after upgrading to MS17 | Refer to documentation
Enhanced Tooling and Visibility
  • RSPAN & VLAN Based SPAN: this feature enhances the current Traffic Mirroring feature by making it more robust and scalable when spanning a session from one switch to another for analyzing port traffic. It provides the ability to utilize VLAN and a physical port as a source and destination when configuring RSPAN sessions between switches along with VLAN filters.  Review the documentation for details.
  • Digital Optical Monitoring (DOM): enables monitoring of real-time parameters of the Meraki transceiver (SFP) such as optical power (input or output), temperature, current, and voltage.  When these parameters exceed the set threshold of the transceiver, users are notified via the dashboard.  This is useful for troubleshooting past and present events and detecting potential network failures to prevent network breakdowns. Refer to documentation for details.
    • Locate this feature: Switching -> Switches -> Select a Switch -> Ports Tab
Upgrade today
We encourage you to upgrade to the MS17 software beta release. While we have tested it extensively in-house, we understand that there may be unforeseen issues that may arise. If you do encounter any issues, please get in touch with support so we can address them as soon as possible.
Head on over to the firmware management page to schedule your upgrades now.  Check out the article in Documentation for step-by-step instructions.
Thank you for your continued support and feedback. We hope that this new release will further enhance your user experience and make our product even more useful for your daily needs.
