Warning Notifications on
Cathie
Why do you still get warning notifications for licenses that have been renewed a month or so previously?  And how do you stop these?
Thanks all
2 Replies 2
bmehta
Meraki Alumni (Retired)
Hello @Cathie,
Under Organization > License Info what is the licensing status for you your organization?
Is it showing "Warning" or "OK"? There is a possibility if the licenses are not correctly renewed and the org is still under warning state.
Feel free to open a case with Meraki support if the org is under Warning state and you need help knowing what licensing issue you are running into.
DarrenOC
Hi @Cathie , sounds like your estate hasn’t been renewed correctly. As above reach out to support or your Meraki AM to verify
