@WillN BT is a trier 1 service provider so they peer in all the EU peering locations and therefore if they have a BGP issue it will, in theory, impact on all their traffic in the EU and potentially globally.
So I would guess that Cisco peer with BT in Europe so any Cisco traffic that is routed via the BT or inside BT's AS number is likely to be affected.
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
