You would connect them to an existing gateway/router or existing network depending on the device. You will want to be sure that they have an accessible internet connection to get them connected to the Meraki Cloud and are added to your dashboard network.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
