Hi, does somebody else have the Problem that the Camera Setting is not Working?
We have 1 Organisation having this Problem. All other are ok. TAC is not helping as they don't know what it is.
So they asked me to see if i find more Organisation having the Same Problem? Have a look at the Picture. It would be grade to find other having the Same Problem. To speed up fixing this Problem.
The green Wheel is turning for ever.
@MichelRueger mine is very fine maybe you chech your internate connection you refresh the browser
From what you have described, while they may have asked for more information on how this looks in any other Organizations you may yourself have access to, I'm pretty certain Meraki Support will not be leaving it entirely to you to take this further or find other affected Organizations. While they may not be able to diagnose the issue directly themselves, I'm sure they will be seeking further assistance to troubleshoot your problem, elsewhere within Meraki.
Could I suggest that, if this is urgent, you telephone Meraki Support for a further update - contact details are under Help > Get help > Still need help? > Call the Meraki Support team
No I do not have any problem on all other Customer I have access to. But he told me that he will look furder if there are other Customer having the same Problem and reporting it to the Development team. So I am looking for other Customer having this problem too.
The problem is that at the moment you can open any kind of case and you get always the same response "I will give it to the development them an come back to you" but you dont hear any thing any more. And this also for Case witch i but on "high"
Just did a rollback from the Version 4.8 to 4.2 and, wonder the Camera Settings are working again. Why do I need to spend more than 1 hours with the TAC and at the end they told me they never had this problem before and they will transfer it to Engineering. And then you don't hear anything again from them? 😞
Hi, same issue here! On first connect of the cam the settings-page worked. After disconnect und reconnect at the costumer it's showing up like in your screenshot!
funny is that exactly this Problem should be solved 🤣
Yep, it is a brand new MV12 which came with 4.8 on it. Do you have a Case-Number? I'll open another one tomorrow...
