meraki solution
meraki solution
Hi
May you kindly lease asist with the below
My client is looking to start a cisco wifi hotspot solution – he is looking for a 4G router – he would prefer something that is computable with Meraki
Thank you!
4 REPLIES 4
Re: meraki solution
Hi @cisco_Meraki
Your client is wanting to use a Meraki MX device with a 4G uplink, correct? Meraki provides some documentation around compatible USB Modems included with their general Cellular Failover information.
Supported USB Modems
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
Re: meraki solution
Assuming a "small" sized hot spot, first get your self an Internet gateway.  I like the MX65 in particular because it has two PoE ports which can be used to power up to two access points.  It comes with two licence options.  Get the Advanced Security licence.  Also note that the 5 year licences tend to be the best value.
https://meraki.cisco.com/products/appliances/mx65
Next get yourself 1 or 2 access points.  I like using MR33's for guest WiFi.
https://meraki.cisco.com/products/wireless/mr33
This Meraki blog entry takes you through the finer detail of setting up guest wifi.
https://meraki.cisco.com/blog/2013/09/secure-guest-access-in-3-steps/
Re: meraki solution
Thank you so much guys for your rersponses
My concern is with mx firewalls how am i going to reach the WAN, internet for example.
Please give me a detailed expanationon how i will achieve that.
Re: meraki solution
@cisco_Meraki, you need to get a 4g modem setup through a provider if you plan on using a 4g connection as your uplink. I provided links to compatible USB modems above, but I think you may have better luck if you can get one that has ethernet connectivity for the MX appliance. I think it would simplify the setup, remove compatibility issues, and allow you to have better interchangeability if needing to physically move your network.
