behind pppope router
Frank1
It appears my meraki is behind pppope router it has the following config
Public ip 209.xx.xx.109
 isp provider url
WAN
Status active
Virtual IP .    nothing
gateway . 192.168.x.1 . (internal router ip)
dns 192.168.x.1 (internal =router ip)
       8.8.8.8
My question is better to setup a sdmz on the router to setup vpn or make the firewall a ppope device and reconfigure it
2 REPLIES 2
corymcglone
Re: behind pppope router
Is your ISP blocking the vpn?  Which type of VPN are you setting up?
If you are doing anything with VPNs it is always more reliable to have the public IP address directly on the MX.
