Issue with MX68
yellowHat
Issue with MX68
Hello
I'm using an MX68 with the firmware 16.14.
I had some customers report that they were unable to communicate between the devices under the MX68 on the same vlan network.
After doing some investigation and also asking Meraki Support team, we found that the APR request from the devices under the MX68 were not working as they should.
We still haven't decided whether to send back the MXs to Cisco.
Has anyone got the same issue? If there are any workarounds I'd appreciate that information!
4 REPLIES 4
CptnCrnch
Never heard or experienced something like that and it definitely shouldn't happen. On the other hand, without knowing the specific bells and whistles within your setup, it's quite hard to give an educated guess.
What exactly did TAC tell you? Possible faulty unit? Maybe, so it'd be worth a try.
DarrenOC
We have a ton of these deployed and not had this issue reported.  As @CptnCrnch  states this could be a single faulty unit.
was the issue resolved, firmware downgrade perhaps?
What did you see exactly? On the same vlan arp should just work between clients without interference of the mx.
BrandonS
Can you be more specific or give an example of the problem?  It is pretty vague what you wrote so I don't think anyone can offer help with just that.
What type of clients?  What testing methodology? What troubleshooting was done?
