Hi All,
I am trying to figure out if it is possible to automate pulling specific event log data for client VPN connects and disconnects, periodically.
I know how to pull the data manually from the dashboard, but this can be a bit tedious.
Not sure if trying to figure out if there is an API that can do this, or if it may be better to get a good syslog server instead.
Anyone else running into this issue? If so what solution did you use to help yourself out with?
Thanks,
RP
