Bandwidth issues with customer
TippTop
Hi guys is there any guide to troubleshooting internet bandwidth issues with Meraki
site has mx67 and a few ms120 switches
have a customer who’s Teams calls are intermittently dropping I suspect issue is related to how they have teams setup but will check that as well
is there a bandwidth health check app available in Meraki?
the site has very few working there with Covid etc
Would appreciate feedback on this?
7 Replies 7
There is a software licence you can buy for the MX called Meraki Insight that is designed to provide additional application visibility.
https://documentation.meraki.com/MI
Is anything else experiencing an issue - or only Microsoft Teams?
Thanks I dont believe they have Insight, typical end user description unfortunately
We do 365 as well but not for them, so it could be well how they have it setup
Is there anything to look out for within the dashboard everything looks fine
Problem is there is so few of them in and getting the right info
I have working on teams roll outs where we asked users to log everything time, internal\external who they were speaking to etc, its a bit different with this company
DarrenOC
Hi @TippTop , on the MX Appliance Uplink page you can view your WAN Loss and Latency stats. Obviously the higher either is then voice quality will suffer.
TippTop
Thanks very much is that the best way to look for it without Insight?
Anything else I could do?
Appreciate the posts from both of you
TippTop
Thanks they look as below , would have thought they were pretty normal
Anything out of the ordinary here, how should they look?Figure1.PNGFigure2.PNG
They look fine, is it only Teams calls that have an issue?  Have you checked that the bandwidth is set correctly on the WAN port to reflect the actual bandwidth (up and down)?
TippTop
Yes its only Teams and another company do their 365
Whats best way to setup bandwidth on the WAN port?
What are the steps involved for that?
Thanks again 🙂
