Add IP Address Without VLAN
I'm using MX250.
Can I add an IP address to the inside network without VLAN?
And then can I use gigabit port as WAN uplink?
1 REPLY 1
Re: Add IP Address Without VLAN
Unfortunately Meraki MX does not provide any such option.
In "Addressing & VLANs" you can disable "Use VLANs", but that will only allow to add static route.
MX250 - can I use gigabit port as WAN uplink?
No, you can't. MX250 has only 2 dedicated 10G SFP+ for WAN uplink.
