Apps pushed but not accessible
Jgrinks
I have an app that is uploaded and pushes to the iPad but when the download is 75% finished the download stops and I'm left with the grey "design" icon and can not access the app. If I look in settings > general > device management it does not show in "apps" under the Meraki management.
Any help would be appreciated
8 REPLIES 8
Re: Apps pushed but not accessible
Apple, Android, or something else?
Can you manually install this app ok?  The device isn't running out of storage space?  Any firewalls/IPS that could be stoping the download?  Are you doing this over WiFi?
Jgrinks
Apple. iPad Pro 2018 12.9 inch. iOS 12.1.3
We are doing over wifi with Meraki MDM. The app is 1.8GB so I one point I thought that may be the issue. We've started trying manual installs but those aren't working either.
You'll need to get it going manually first (this is not a Meraki issue in this case).  It may well be this app is damaged on the app store.
Jgrinks
It's an enterprise app, so it's not passing through the App Store.
Oh,ok.  What are you downloading it from?  A web server?  An Amazon S3 bucket (my favourite)?
Jgrinks
We've uploaded the .ipa directly to Meraki MDM.
Jgrinks
Currently when we try a direct upload we are getting a "can't find device id" error.
Jgrinks
I realize: Are there any known issues with with iPad Pro using a different style of UDID for permissions?
