SP-Initiated SAML SSO for dashboard and mobile now available - Early access
SP-Initiated SAML Single Sign On (SSO) is now available for all customers on the Early Access page in the dashboard! This is a fully cross-compatible upgrade to existing Meraki dashboard SSO that allows customers to now use two different types of SAML SSO for the dashboard to best fit their deployment.
This also means that SSO login is now available for the Meraki mobile app! (iOS/Android)
To learn more about this new feature, check our documentation, SP-Initiated SAML SSO Configuration Guide. To compare or learn more about Meraki’s different SAML login types, check out Configuring SAML Single Sign-on for Dashboard.
How to opt in
In the dashboard, navigate to Organization > Early Access. Opt-in by clicking the toggle button for SAML SSO.
How to provide feedback
We care about your feedback, and are actively reviewing feedback and issues related to SP-Initiated SAML SSO. While using the Early Access page, use the Give your feedback button in the bottom-right corner of the page.
Alternatively, if you have feedback for SAML SSO in the mobile app, use the Settings tab, and select Make a wish to leave feedback.
