Meraki Dashboard API Python Library
This library's goal is to refresh and supplant the legacy module (this repository versions 0.34 and prior) as well as the now-deprecated SDK. Here are some of the features in this revamped library:
- Support for all API endpoints, as it uses the OpenAPI specification to generate source code
- Log all API requests made to a local file as well as on-screen console
- Automatic retries upon 429 rate limit errors, using the
Retry-After field within response headers
- Get all (or a specified number of) pages of data with built-in pagination control
- Tweak settings such as the default base URL (for example, to use with V1 and/or mega-proxy)
- Simulate POST/PUT/DELETE calls to preview first, so that network configuration does not get changed
- Includes the legacy module's functions for backward compatibility
