MT Sensors - The Newest Meraki Product Offering
Saralyn
Meraki Alumni (Retired)
We recently announced an all new product offering - Meraki MT sensors. There are three models of MT sensors:
  • MT10 temperature and humidity sensor
  • MT12 water leak detection sensor
  • MT20 open/close (intrusion) sensor
Sensors are managed via the Meraki dashboard, and use existing Wi-Fi 6 MR access points and second generation MV smart cameras as gateways. This makes MT sensors simple to deploy and easy to scale, and eliminates the need for on-premise management and dedicated gateways found in traditional sensor systems.  With flexible alert options, including SMS, email, and push notifications, MT sensors make it easy to keep tabs on your environment.
For more information, check our websiteblog, documentation, or the MT sensor forum.
