Python Delete Org Admin problem
damienleick
Hi I encounter a problem for deleting a user with API
My code :
##Credentials
MY_API_KEY = 'xxxxxxxxxxxxxxxxxx'
MY_ORG = 'xxxxxxxxxxxxxxxxxxx'
##Inition de la library Meraki
import meraki
import json
import csv
##Inition de l'API
dashboard = meraki.DashboardAPI(
        api_key=MY_API_KEY,
        base_url='https://api-mp.meraki.com/api/v0/',
        #Désactivation/Activation du debug
        print_console=True,
        #Désactivation/Activation du logging
        output_log=False,
##Debut de Script
with open('user_delete.csv''r'as csvfile:
    users = csv.reader(csvfile, delimiter=',')
    next(users)
    for id_user in users:
        dashboard.admins.deleteOrganizationAdmin(MY_ORG, id_user)
reponse code :
Admins, deleteOrganizationAdmin - 404 Not Found,
Traceback (most recent call last):
File "delete_user.py", line 34, in <module>
File "C:\Program Files (x86)\Python 3\lib\site-packages\meraki\api\admins.py", line 97, in deleteOrganizationAdmin
return self._session.delete(metadata, resource)
File "C:\Program Files (x86)\Python 3\lib\site-packages\meraki\rest_session.py", line 232, in delete
self.request(metadata, 'DELETE', url)
File "C:\Program Files (x86)\Python 3\lib\site-packages\meraki\rest_session.py", line 153, in request
raise APIError(metadata, response)
meraki.exceptions.APIError: Admins, deleteOrganizationAdmin - 404 Not Found,
C:\inetpub\wwwroot\merakidevops\script\Admin creation\Create Agent V3.0\Move and change\Delete>pause
6 REPLIES 6
Nash
You're getting a 404, which means bad URL - resource not found.
Are you able to run dashboard.organizations.getOrganizations() using the same parameters?
What happens if you remove base_url?
@Nash
If I remove the base URL i have the same error  (i have multiple script who have this base url and they work with no problem)
The GetOrganization work
Nash
@damienleick wrote:
@Nash
Okay cool, so the base works. That makes life easier!
Here's how I'd tshoot this:
  1. Does getOrganizationAdmins work as expected? I.E. your org num is good?
  2. If you run that for loop and print(id_user) instead of del admin, do you see the admin IDs you expect to see?
  3. If you get admin IDs that match admins in getOrganizationAdmin, try running with a try-except structure. I messed with Postman: if you have an admin ID that doesn't match an admin in the org, you also get a 404 error.
What if you do a try-except like:
with open('user_delete.csv', 'r') as csvfile:
    next(users)
        try:
        except:
            print(f"No admin {id_user} found.")
If that works, do go back and clean up that except so it's not a blanket exception... This is quick and dirty.
Where did you get the id_user values from?
Edgar-VO
From the .csv file which he is reading
Nash
Okay, where did you get the data that you've put into the CSV file?
