Inconsistent splashAuthorizationStatus PUT behaviur
Cesar-A
Hi!
I'm trying to expire a session using the Meraki API splashAuthorizationStatus, however nothing changes. I'm not sure if that problem it's related to this Locales are not supported because we're using a composed network
Actually I'm using the networkID that I got from the Deep Link because when I did the PUT using the netwok ID from https://api.meraki.com/api/v0/organizations/<organization>/networks I got the error that is mentioned on the ktzanet Post  {"errors":["Locales are not supported"]} and HTTP code 400.
This is my PUT body
https://n27.meraki.com/api/v0/networks/N_578149602163765230/clients/a4:71:74:45:f8:ec/splashAuthorizationStatus
{ "ssids": { "0": { "isAuthorized": false } } }
And this is the response from the API
    "ssids": {
        "0": {
            "isAuthorized": true,
            "authorizedAt": "2019-06-04 15:49:23 UTC",
            "expiresAt": "2019-06-05 15:49:23 UTC"
That doesn't make any sense, Am I doing something wrong?
5 REPLIES 5
BrechtSchamp
This works for me:
What tool are you using for it?
DexterLaBora
You have likely run into two known issues:
- the endpoint does not support combined networks.  (This is planned to be fixed)
- api.meraki.com/.. redirects to n27.meraki.com/...    this redirect will cause issues with PUT/POST operations, commonly with JS, as it does not follow the redirects properly or will drop the body along the way.   (this is planned to be fixed)
Temp Workarounds:
- use non-combined network
- hard-code your org's URL (i.e. n27.meraki...)
Hope this helps
Temp Workarounds:
Hope this helps
Interesting... The network I tested this on is actually a combined network. Perhaps it's already fixed?
Based on what he wrote in the opening post, it seems to me he was already using the hardcoded links too.
You're right on both.
- this endpoint now supports combined networks.
- the request was to the org's URL.
I tested without issues.
Here is a cURL example, where I also added the -L flag to follow redirects (FYI)
curl -LX PUT \
  https://api.meraki.com/api/v0/networks/L_123456789000/clients/24:18:1d:ff:ff:ff/splashAuthorizationStatus \
  -H 'Content-Type: application/json' \
  -H 'X-Cisco-Meraki-API-Key: <API-KEY>' \
  -d '{
  "ssids": {
    "3": {
{"ssids":{"3":{"isAuthorized":true,"authorizedAt":"2019-07-08 15:52:16 UTC","expiresAt":"2019-07-08 16:22:16 UTC"}}}
It might be best to share a code view, or trace the http requests to see if something is missing.
Im having the same problem, but only if the network is bound to a template.
If the network is not bound to a template - it works.
Do you know this ment to be like this? i reckon this should work either way no?
