Restricting IOS Camera Image Quality
MikeRace
Hello All.
Ive been trying to figure out if its possible to restrict the IOS Camera within Meraki to set the image quality?
Are there a list of IOS Restriction Keys for the Camera anywhere?  Ive searched the forums/web but cant find anything?
Any help would be much appreciated.
Kind Regards
Haydn
I believe the only control you have over the camera is to disable it or not, it's not a limitation of Meraki just not something Apple allows you to have control over. I'm sure someone will correct me if i'm wrong
MikeRace
Wondered if it could be set via here
MikeRace
Haydn
No, I dont think Apple have utilised App Config in their apps
