Hardware support for Meraki devices
CarlT
Hi All
When you buy a dashboard licence with a Meraki AP, does this also include hardware support for the AP?
Many thanks
6 Replies 6
rwiesmann
Check out the F&Q for Licensing:
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Licensing_FAQs
How does the hardware warranty relate to licensing?
The hardware warranty is tied to the hardware unit, not the license. Hardware that has a lifetime warranty (e.g., the MR24) is warranted for the life of the hardware. Hardware with a fixed-term warranty, (e.g., 1 year), has a 1-year warranty, regardless of the license.
Hope this helps
Roger
Yes, the license includes replacement despatched (usually) next business day of any devices that fail
Edit - this is for internal models only, as @rwiesmann stated, external APs and antennas only have a 1 year warranty...
Inderdeep
@CarlT the answer is yes
www.thenetworkdna.com
BrandonS
For new, yes, but if you purchased used hardware then no the hardware warranty is not transferable.
Make_IT_Simple
Meraki Alumni (Retired)
Bruce
And remember that if the warranty response time isn’t inline with your requirements, e.g. you want a 4 hour advance replacement (not something you’d normally want on an access point), or if the warranty is only for a year and you want to extend it, then you can get MerakiNow which is very similar to SmartNet in that it provides hardware replacement.
