AP's dropping of network
TomasB
Hi all, we have started getting problem from all different sites with AP's dropping of network (or loose connection) since around  3-4AM this morning. I'm not sure if its our firewall or just the connection to Meraki cloud or if Cisco has problem? Have you notice anything?
[Update 09:35] Got this link:
https://community.meraki.com/t5/Meraki-Service-Notices/bg-p/service-notices
[Update 12:45] Still not solved. We're having lot of connection problems between AP/MX and Cloud.
29 Replies 29
redsector
Same Problem here all MR36, MR46, MR46E, MR55 are affected saying "no connectivity".
But all MR42, MR42E, MR33, MR32, MR18 are not affected, also all switches are not affected.
michael12
Same problem !!!
HakobDavtyan
The access points and MXs are being disconnect and connect continuously from the cloud
TomasB
Our MX's and MR44, MR76 is affected.
ChrisB
It would appear this is a known issue by Meraki this morning, impacting Europe based customers. Just called them and they have a text to speak message advising.
User traffic appears to be fine, just the monitoring/dashboard part is having issues
AntonP
Hi TomasB
The same is going on here, fairly new environment. Mx250 and 105 APs are effected.
No response from Meraki
pffff
Best,
Anton
JesperMortensen
redsector
The devices are working well, only the dashboard connection is affected. Users don´t see any trouble.
AxL1971
same here in the UK, up and down since 3am
AntonP
Hi AxL1971,
The ap's in Amsterdam seem to be connected again,
only things like RF spectrum are not working
AxL1971
we have a mixture of AP's and MS switches, only the AP's lost connection to the dashboard, the switches did not
The service ticket has been updated and we stopped seeing issues about 30 minutes ago.
redsector
Still a few AP´s not reachable
AxL1971
samere here started again, so not entirely resolved.
Gewessler
Same Problem.
AUK
We had around an hour of stability and now APs are reporting as offline and then back on repeatedly.
AxL1971
ChrisB
Your best off referring to https://community.meraki.com/t5/Meraki-Service-Notices/Dashboard-connectivity-in-Europe-region/ba-p/... the official thread on this, rather then the unneeded updates of peoples individual status
AUK
To be fair that thread had the issue still marked as resolved when most of the most recent updates were posted.
The posts here were a useful resource to see that I wasn't the only one and saved me from making a call to Meraki support as was advised on the official thread.
Only WiFi6 APs and MX250s affected for us as well:
redsector
It was marked as solved, but it isn´t. Problems still occure.
AndyDee119
Still seeing the issue here wth MR44 APs reporting as down across our sites.
Gewessler
SergeD
It says user traffic is not directly affected but it is. The network drops for up to a minute every time it happens. No internet.
@SergeD are you using 802.1x?  The service alert says that this may be affected.
SergeD
nope, just PSK. This is my home network. Haven't checked work network yet which is also in the UK. Its all good now though. Dont know about you guys?
redsector
Seems to be good now, no issue since an hour.
JonP
We last saw an issue at 12:42 GMT, so fingers crossed this issue is resolved.
Gewessler
Here we go again.....#
https://community.meraki.com/t5/Wireless-LAN/AP-showing-as-offline-on-Portal/m-p/146214
https://community.meraki.com/t5/Wireless-LAN/AP-s-dropping-of-network/m-p/146244#M20410
And Here the "Resolved" tread:
this is not acceptable.
Last week, there were again these incorrect displays for various customers.
Your developers should not smoke so much pot
