AP showing as offline on Portal
AxL1971
Has anyone had the issue where AP's are showing as offline on the portal, yet I can PING them from our internal network and all operational.
For us, this was across multiple networks/sites so not specific to one network.
Was there an issue with the portal in the past 12 hours ?
Another network
10 Replies 10
MarcP
Had the same problem with a single device yesterday afternoon... (18hours ago).
Seems like there are some bugs in the dashboard at the moment:
https://community.meraki.com/t5/Wireless-LAN/Again-dashboard-problems/m-p/145623
Agus
I have 3 meraki but running well until now, is it possible internet connection/internet provider connect to meraki dashboard/cloud?
MarcP
What you mean?
"is it possible internet connection/internet provider connect to meraki dashboard/cloud? "
Agus
hi,
sorry as i experience, when my internet provider problem so the device detect down/offline on dashboard, if internet connection working well it should be access point show online on dashboard, sorry for make confusing
MarcP
As the Dashboard is not local, this is the normal behaviour, yes 🙂
Gewessler
Same...
Jeizzen
Maybe related to Meraki info in 'Release Notes' of recent MX, MR firmwares
Important note
  • Meraki APs use UDP port 7351 for cloud communication and TCP ports 80 and 443 for backup communications when running MR 27 and older firmware. When running MR 28 firmware, Meraki APs will now use TCP port 443 as the primary means for cloud connectivity. In order to maintain connectivity to the Meraki cloud on MR 28+ ensure that TCP port 443 is allowed to communicate with 209.206.48.0/20 on firewalls that are deployed upstream of your Meraki APs. (Wi-Fi 6 MRs)
Or if you're in Europe (eventhough it has been resolved):
https://community.meraki.com/t5/Meraki-Service-Notices/Dashboard-connectivity-in-Europe-region/ba-p/...
AxL1971
Our firewall allows TCP port 443 to communicate with 209.206.48.0/20
AxL1971
been ongoing this issue all day .. up and down like a yo-yo
Jeizzen
I guess need to open a case
