P2P application support with W-Fi configuration
kukku
HI Expert, I need to develop Wi-Fi P2P based application for following system configuration.
Device A (with Wi-Fi Module) connected to Device B (does not have Wi-Fi module) through ethernet link. I need to support one P2P based application on Device B. Would it be possible assuming VLAN group is supported in system?
7 REPLIES 7
BrechtSchamp
Re: P2P application support with W-Fi configuration
I'm not sure what you mean by P2P, that could mean many things. However if you just need device B to connect to the Wi-Fi network through device A then it is possible.
It's a very ghetto way if doing things, but what you need is called bridging network adapters:
https://www.windowscentral.com/how-set-and-manage-network-bridge-connection-windows-10
Basically you tell windows to transfer packets between the wired and the wireless interface on device A. I'm assuming having device A and B on the same VLAN is okay. If not, then I think this solution will not work. Likewise if you need 802.1X I doubt it would work.
kukku
Sorry I didn't explain clearly. By P2P (peer to peer) I meant Wi-Fi Direct. Assuming Device A and Device B are part of same VLAN group, then is it possible to have run WiFi direct based application (e.g. WiFi printing) on Device B.
BrechtSchamp
I'm afraid I still don't understand. So device B supports Wi-Fi direct, but doesn't have a WiFi card?
kukku
Device A supports Wi-Fi Infrastructure as well as Wi-Fi Direct. Device B (does not have any Wi-Fi module) is connected to Device A through ethernet link. Assuming I am allowed to make software changes on Device B (in worst case on Device A as well), is it possible to run Wi-Fi Direct based application on Device B?
BrechtSchamp
Honnestly I have no idea. You're talking about some sort of proxy WiFi direct interface on device A with in the backend some IP based interface on device B.
kukku
Thanks. Yes, your understanding is correct. Not sure but was thinking adding Device A and B in same VLAN would help.
kukku
Thanks a lot Mr. @BrechtSchamp . I think not many have experienced this kind of use cases hence issue can closed.
