zero touch provisioning
NABILOU
I would like to deploy many configurations on many switchs, most of switch have same configuration but : the name, ip and default gateway.
Could you please tell how to deploy on many switchs and how to automate the name and ip add, default gateway for each switch ?
Thank you for your help
NM
BrandonS
Check out Meraki.io for API documentation and demos.  Here is one that might be a good start for your requirements: https://create.meraki.io/build/google-forms-with-the-dashboard-api/
5 Replies 5
you could use dhcp for ip and gw.
 you can use API to push the name and others settings
NABILOU
thank you a lot for your help.
BrandonS
Adam
You could also setup one switch and clone the configuration to the others in the dashboard.  With that method you still have to configure the switch static IP, name, location information.  But the ports would be config'd.
NABILOU
Hi Adam, thank you for reply. I thought that I could deploy with configuration templates. I can't use this option
