Migration from Dell switch to Cisco switch
NABILOU
I have to migrate  Dell switch to Cisco switch Meraki. So we have many Vlans on Dell and each vlan is assiociate to range on DHCP like this : lan association subnet 10.2.2.0 255.255.255.0 2
could you please tell me what is yhe same command on Cisco ?
Thank you
Nabilou
Accepted Solutions
Re: Migration from Dell switch to Cisco switch
you just add the ports to the correct vlan @ switch > switch ports
if you want to relay, you go to switch > routing and dhcp
11 REPLIES 11
meraki is gui based. so you create a vlan, and enable dhcp service or forwarder on that vlan.
NABILOU
Thanks fo the answer. sorry we oreded and we haven't got them yet.
So, you mean I have 2 options :
1 enabled DHCP   or forwarder on vlan : with Bonjour Forwarding ?
NM
Is your Dell switch acting as a layer 3 gateway for these vlans?
What is doing DHCP in your network?
NM
forward to dhcp server(if you have one) . here is some documentation https://documentation.meraki.com/MS/Layer_3_Switching/Configuring_DHCP_Services_on_the_MX_and_MS
NABILOU
Layer 2
NABILOU
Thanks a lot 😉
The if the Dell switches only operate at layer 2 then you only need to configure the VLANs and nothing else.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Configuring_Multiple_Switch_Ports_on...
BlakeRichardson
As mentioned Meraki is a GUI based system, there is no CLI. I suggest you familarise your self with the Meraki Dashboard before you jump into swapping the equipment over just to be safe, You dont want to rush things if you dont havea good understanding of Meraki.
Good luck!
NABILOU
Hi, I got the switchs (MS-120). do you know how to create the vlan please ?
NABILOU
Ok I got it, thank you for your help
