Power Supply cable
IAHITCN
Power Supply cable
Do I need to turn off my switch in order to add the second power cable ?
2 REPLIES 2
Are you referring to an actual power cable - or a whole redundant power supply?
Actually let me change my response.
If you have an MS250 or above switch then the power supplies are hot swappable.  So you can just plug it in without turning the switch off first.  And you can plug in the power cable any time as well.
