Hi all-
Sorry for the delay. Thanks for the great informative links and info. Very useful and tried soaking it all in.
Going down the path(now) of having the ms250 doing DHCP for V+D and vlans(vlan96=data/vlan168=voice)
What i tried:
Tried having the Sonciwall pass through VLAN of 96(D) and 168(V) and individual scopes for each through the X10 interface on the swall to the Meraki switch set to access port and have 96 and 168 assigned on that port.
Results:
The phone plugs in and gets the 168 vlan show up.
No dhcp is passing through to the switch from the SW. See's the device, but no IP assigned.
Swall x10 setup:
Not sure why the sonicwall is not passing through IP's via appropriate scopes down to the switch.
DHCP scopes pushing the 192.168.96.x range(data) and 192.168.168.x range(voice) through the swall x10 interface with is connected to the meraki switch.
Since going down the potential route of having the ms250 handle VLAN and DHCP requests, I've run into this issue out of the gate.
Having Ip assignment error when setting interface IP for the DHCP section.
Questions:
Current Ip of switch:
- IP:192.168.96.172
- sn:255.255.252.0
- gw:192.168.96.1
I tried different Ip's on different subnets, tried no ip - all with same error.
What am I missing? (embarrassed missing the concept on this...)
Other questions:
I see the reservations tab, but no scope option? Is that handled by the subnet mask native formulas?
(we need a scope on the Vlan96/data to be : 192.168.97.1-192.168.99.250) 192.168.96.1-254 is reserved
After setting this interface with 96(VlanData), then do i create another for 168(Voice)
Hopefully, this makes some sense.
Thank you all
