Hi Mytestcase,
I hope your day is going well.
I would like to highlight a few very important points:
1) Dashboard organizations should always have at least two organization admins with full permissions. This is best practice in case one account is locked out or if access to that account's email address is lost.
Most importantly, make sure your Organization also has Admin accounts with Full privileges just in case, and not only the MSP. Therefore, request the current MSP to create Admins accounts for you and make sure that you can successfully login.
2) By policy, Cisco Meraki’s support team does not make dashboard configuration changes on behalf of the customer. Dashboard administrators must make their own configuration and account changes on the Meraki dashboard. Just as Cisco Meraki will not make any configuration changes, they can not make any adjustments to organization or network permissions; all changes to the dashboard administration must be made by an existing org admin on that dashboard account. Please refer to section 5.2 of our End Customer Agreement for details.
You (not Cisco) are solely responsible for maintaining administrative control over Your Dashboard account.
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Managing_Dashboard...
3) Has the current MSP created the current Organization, or you have given them only permissions to manage it?
- Manually Moving devices between Organizations - For organizations that are following the co-termination licensing model, this must be done manually.
- Per Device licensing:
- Organization Split Overview and FAQ:
