how to export policies MX from one org to others as moving MX
ThanhTongMeraki
hi team,
EU have one org which has many the combined networks with full MX, MS, MR. The EU want to split orgs and move networks to new org ?
how to export policies MX from one org to others as moving MX ?
Best regards.
Dunky
It may be worth looking at a product called Migration from Boundless - Boundless Migration | Meraki Apps | Move Networks & Devices
They are a Cisco Solutions Partner focused on Meraki and I am currently looking at their SafeGuard product.
5 Replies 5
Mloraditch
If you do an org split all settings will just move over see here: https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Organization_Spli...
if you want to export settings to put into an empty org you would have to use the API. There may be some third party solutions that help with this, but Im not specifically aware of any.
Dunky
ThanhTongMeraki
Thanks a lot Dunky,  Could you know any documents to instruct technical guys to self-build this tool ?
Dunky
Unfortunately no, I've never had the time to look at API's.  I would imagine it's a fairly complex operation that could take some time to replicate even if I had the skills!  🙂
Mloraditch
Any tool like this is going to involve running nearly every get and put API Call available for whatever products you want to move. It would be incredibly detailed and complex. I would get a quote from Boundless for what you want to do before even asking a dev to scope out the cost of building something custom.
