Port Not Forwarding Traffic Due to Access Policy
gbpirate2
Adding the following config within the C9300-24H, and still get the alert Port not Forwarding Traffic
conf t
int range g1/0/1-24
device-tracking attach-policy MERAKI_ACCESS_TRACK
end
wr
2 Replies 2
Can you show how your policy is configured?
And have you checked the switch logs?
Mloraditch
If you are adding config via the CLI you have a hybrid/monitored switch. If traffic is not actually being blocked this is likely some sort of data/gui bug with how the dashboard is reading your CLI config. I'd open a support case. If traffic is actually being blocked you may want to consult the regular community.cisco.com or regular TAC to look at your config, while many of us are familiar with both modes of deployment there are many more folks familiar over there.
