Hello community:
Can someone please tell me how can I access the status page from my personal pc.
I tried on my browser: https://80.1.1.1:443 but without success.
You need to allow the remote ip or any at the firewall page. And set enable remote device status page at network general https://community.meraki.com/t5/Security-SD-WAN/local-page-MX-from-remote-not-display/m-p/11126
I already set the value to "Any" but I cannot reach the page from my phone
I tried to open the URL: https://80.1.1.1:443
Did you also set "enable remote device status page" at network general settings?
Is the branch mx behind another (nat) router?
Yes I did it.
The MX is behind the FAI router.
I dont see that in your drawing. But i supose that router is blocking something then.
I dont know if you really trying 80.1.1.1(uk ip address) or just used it as example in the drawing. Is that what is showing on the mx status page at wan1?
While this is possible it's a security risk allowing this. You would be better to use a VPN rather than opening it directly to the world.
