MX84 - Policy by IP block
We have a MX84 in front of a router which has all the vlans configured.  Is there a way to configure group policies on a ip subnet basis instead of client per client?  Is it necessary to pass this vlans to the MX84?
Thank you
Ricardo
1 REPLY 1
Re: MX84 - Policy by IP block
Ricardo_J, you can apply group policy to a subnet but instead must use the VLAN method. In doing so you would need to move the VLAN routing to the MX for that method to work. The thread below discusses a similar scenario and the second link is to the Group Policy documentation. https://community.meraki.com/t5/Security-SD-WAN/group-policy-per-vlan-and-switch-setting/m-p/24114 https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Poli... I hope that helps.
Adam Slater
Senior Technical Evangelist
Training & Evangelism Team
