AnyConnect Auto Connect After Login Without Password (Meraki MX)
jOMeraki2
I’m using Cisco AnyConnect with a Meraki MX.
Is there a way to make the VPN connect automatically after the user logs in, without asking for username and password every time?
Maybe using SSO?
Thanks!
1 Reply 1
Only using certificate-based authentication.
Sentry AnyConnect VPN is a special Cisco Meraki integration between MX and Systems Manager (SM) enrolled devices. This allows secure and automatic certificate-based Always-On AnyConnect VPN for SM managed devices. SM managed devices will be sent all the necessary configurations, certificates, and app settings for an Always-On VPN tunnel back to the MX. For SM enrolled devices, the end users are not interrupted with any authentication/setup steps and the VPN tunnel will open automatically
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Configuration_Guides/Client....
