Deprecation notice: OpenAPI Spec v2 ‼️
Oren
Meraki Employee All-Star
We are announcing the deprecation of the Meraki Dashboard API OpenAPI Specification version 2 as we transition to the enhanced and more robust OpenAPI Specification version 3 (OASv3). This update reflects our commitment to providing you with improved API capabilities, better developer experience, and more accurate data handling.
Key change:
Starting September 1, 2026, updates to the Meraki OpenAPI Specification version 2 (OASv2) on GitHub (https://github.com/meraki/openapi) will cease. The last version of OASv2 will remain available to users, but all subsequent updates will be made exclusively to OASv3.
What this means for you:
  • All API operations will keep working as usual.
  • If you are consuming our OpenAPI spec, we recommend migrating to OASv3 at your earliest convenience.
Thank you for your continued partnership. We look forward to supporting your success with the enhanced capabilities of OpenAPI v3.
The Meraki API team.
2 Replies 2
Where is the new spec published?
Oren
