Logging in L3 firewall
Juraj22
Hello guys,
i would like to ask, if is some possibility to see traffic passing firewaal rules. There is some hits next to rules, its fine indicator, but is some more options for checking what is blocking and what is fine?
Fot example, we hase 7-8 vlans, maybe 5-6 blocking and many allowing rules. Is some debbuging or logs? In standard logs is not that informations.
Thanks for reply.
Juraj.
2 REPLIES 2
Not from the dashboard view.
The mx can send flows and hits to a syslog server
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Syslog_Server_Overv...
RaphaelL
You can only see the firewall hits if your network is not bound to a configuration template. Once you are bound to a template you can't see hits. Like ww said , to see all the details you will need a syslog server.
